My 1984 ford f150 300 6 cylinder is running too rich to the point it fouls the plugs, I've tried everything.
It has 125000 miles, but is still a good truck. Help.
Sunday, May 7th, 2006 AT 6:04 AM
IMPORTBASHER89
MEMBER
Does it have a carb. It could also be insuffciant fire (low spark) try lightly tapping on the flowt bowl area of the carb while cranking or running(lightly)
Monday, May 8th, 2006 AT 8:45 AM
MITCHY
MEMBER
I've tried all but taking a hammer to it. I've changed the distributor and the TFI module, checked the wiring and it does have a carb.
Monday, May 8th, 2006 AT 6:06 PM
IMPORTBASHER89
MEMBER
It mite be out of time or have a lot of slack in the timing chain also could be the float sticking in the carb
try the tapping thing first (lighty on the carb where the inlet hose (fuel) is
