1994 Ford F-150 Stuck Starter Bolts Fix
RICKM
I have a 1994 ford f-150 with 68000 miles. I received it from my mother after my father passed away. The truck sat for several years only being started on occasion. The starter failed and all I got was a clicking sound from it. I replaced the starter solenoid but that has not helped. I tried to remove the starter but the bolts will not budge. I tried heat, penetrating oil and good old muscle but the bolts wont give. The heads are stripped now and even a pair of vise grip pliers wont budge them.
I was wondering, if I used a torch and cut the heads off, would there be enough bolt left to get a vise-grips on it to remove the rest and replace with new bolts.
Any other ideas would be helpful! I need help!
Apr 16, 2006 at 1:45 PM
LOSONE
  • 1,616 POSTS
Hummm a bad scene. The only way to get the bolts out would be the blue flame. I hate to see it used on that part of the truck so have someone with a hose. I had it happen to me one time. I took/ broke the starter apart, heated what was left of the bolts and they finally came with (*(&^)))(_&*$^$ and skinned knuckles. Good luck
Apr 16, 2006 at 1:49 PM
Suggested Repair
Use a torch carefully with someone standing by with a hose. If needed, break the starter apart, heat the remaining bolt shanks until they loosen, grip and remove them, then install new bolts.
Conversation Summary
The owner of a 1994 Ford F-150 with 68,000 miles that sat for years has a failed starter that only clicks. Replacing the solenoid did not help, and the starter mounting bolts are seized and now stripped. The expert advised using a torch carefully with a fire watch, breaking the starter apart if necessary, and heating the remaining bolts until they can be removed.
