Starter
OLIPHANT
1995 Ford 150 Pick up truck, 200,000 km. We lost until now five starters over the last 8 years. Something is causing our starters to become faulty.We checked our battery, which is fine. Our car maintenance is always our priority. What are the potential problems? Thank you.
Jun 25, 2007 at 7:52 AM
MERLIN2021
  • 17,250 POSTS
Buying cheap rebuilds...get a good one!
Jun 25, 2007 at 8:37 AM
JWALTH02
  • 180 POSTS
Have you checked the battery to starter wires for damage? And all your wires going off of the starter?
Jun 25, 2007 at 11:15 AM
OLIPHANT
RE: Ford F150 Engine 351 8cylinder
We have checked all wiring by prefessional mechanics. No faulty wiring was found. Out of 5 starters we replaced only one was rebuild.
Jun 25, 2007 at 2:05 PM
JAMMIN67
could be that ur holding key to long when u crank the starter. should not be more than 1 second before start. if its taking longer 2-3-4 seconds ur problem lies elsewhere. therefore excess grinding of ur starter causing it to fail prematurely.
Jun 25, 2007 at 4:33 PM
