To whom this may concern,
My name is Chris and I own a 2000 Ford F-150 with the 4.6 Triton in it.Recently I have been having a really big problem with the truck.The truck runs fine when cold,but after driving for a while...usually more than a half an hour I have a problem starting it after I turn it off, usually when it is warm and has been turned of for more than 5 minutes.When I try to start it it stalls right away.I noticed that if I keep my foot on the gas and have the rpm up(around 2000rpm) for a couple of minutes, it will idle ok and everythings fine.But it has been getting worse ! Now the problem doesn't go away unless the engine cools and if I try to drive it I have to drive it with 2 feet to keep the rpm up at a red light.It runs fine if I continue to move but when I pull up to a red light it stalls.I thought it might be the air charge temp. sensor,but that didn't fix it.It's obvoiusly a problem only when its warm.Do you have any clue why this might be happeneing ??? Sorry for the long question , but I wanted to explain it as best as I could. Thank you for your time !!! Mr Cogis
Aug 22, 2007 at 4:48 PM
