Shift Cable
JASONMICHEL
  • 17 POSTS
Have a F-150 supercab 4x4 4.9l with automatic. I think the shifter cable is bad, where can i find one, and what all entails changing it. It will shift fine into drive, but have to crawl under truck to get it to disengage and go into park. thanks
Nov 8, 2007 at 2:35 PM
JASONMICHEL
  • 17 POSTS
the bracket was replaced, and i crawled under and noticed the rubber sheathing is pulled away? is there any diagram to show how to unhook and put new one on?
Mar 24, 2021 at 6:54 AM
JASONMICHEL
  • 17 POSTS
the sheathing under the truck, the bracket you told me to replace is brand new and installed correctly, there is a bracket right before where the other end snaps into the tranny, right there the black rubber sheath is pulled away so when the lever is moved, that sheathing moves but the cable does not
JASONMICHEL
  • 17 POSTS
[quote:0b8f1c5fac="justanold"]..HELLO!
Does your transmission shift correctly into all positions now? 8) 8) 8)[/quote:0b8f1c5fac]it will shift into reverse then neutral and down into the drives but not back up and into part, still have to crawl under truck and manually disengage
