1992 Ford F-150 Rough Cold Idle
JASONMICHEL
  • 17 POSTS
I have a 1992 F-150 4x4 with 5.8L, when starting up when cold, it won't stay running unless i step on accelerator immediately after starting and pump it a few times to keep it running, even then, after that and it sits at idle its very rough running until warm. any ideas? or does this sound like simple tune up, and if that is the case what do you recommend changing during tune up?
Nov 11, 2007 at 3:02 AM
BLACKOP555
  • 10,386 POSTS
If yours has a MAF sensor clean it with qd cleaner. may be making engine run lean.
check coolant temp sensor and sending unit.
can be making engine run lean also, causing it not to have enough fuel to stay running when cold.
Nov 11, 2007 at 3:50 AM
FORDFAN
  • 9 POSTS
check your spark plugs. Does it almost miss when you are driving it from a stop to 60mph? if it misses some i would definetly check your plugs. If not your MAF sensor or O2 sensors on the exhaust might be bad.
Nov 11, 2007 at 6:36 AM
JASONMICHEL
  • 17 POSTS
well the check engine light is on but haven't got the code, and yes it runs and kinda misses at low speeds
Nov 11, 2007 at 7:06 AM
FORDFAN
  • 9 POSTS
So i would pull the last 2 spark plugs and see if they are black, if so then pull them all and replace them. My buddies truck did the same thing and we pulled the last 2 plugs and they were jet black. We replaced and the sucker runs smoooooooooooooth
Nov 11, 2007 at 8:08 AM
JASONMICHEL
  • 17 POSTS
pulled plugs and they were all white, and a couple were gapped wrong, still runs rough as hell at idle, seems to run a little smoother under power though. I found that the idle air control motor was unplugged, i plug it in and it idles smooth, but at about 1500rpm and won't come down, unplug it, idle comes down but rough and check engine light comes on...any ideas?
Nov 16, 2007 at 12:28 PM
BLACKOP555
  • 10,386 POSTS
good good, can you take a picture of your IAC if you can post it here and i can tell you if you can clean it or if yours is not the cleanable type model.
the cleanable one is striaght with a plug at the end, the uncleanable one is like the straight one only the plug at the end comes out at a 90 degree angle.
hope this helps
Nov 17, 2007 at 1:45 AM
JASONMICHEL
  • 17 POSTS
it's the 90 degree one, but why can't it be cleaned?
Nov 17, 2007 at 5:09 AM
BLACKOP555
  • 10,386 POSTS
certain ones have the removable inside parts, but the one you have i belive may have parts pressed in, and it may not be able to be put back together properly.
Nov 17, 2007 at 2:10 PM
JASONMICHEL
  • 17 POSTS
you are correct, but i took it off anyways and cleaned what parts i could see with throttle body cleaner. the mounting surface to the intake and the throttle body itself. The IAC looks almost new. i changed plugs, wires, cap and rotor, cleaned airbox and new filter. still runs rough at idle, idles about 1k-1.2k surging like, kinda runs rough under power in low rpms and at stand still in gear. Is there anything else i can try, this is driving me batty
Nov 17, 2007 at 2:14 PM
BLACKOP555
  • 10,386 POSTS
well i still would like you to replace it, never would hurt, they can be tested at autovalue.
scan for trouble codes while your there also.
only other thing i can think of is MAF and coolant temp sensor, but im almost certian it is the IAC
Nov 17, 2007 at 3:00 PM
JASONMICHEL
  • 17 POSTS
you think autozone can test it? don't have an autovalue around here. and can they test it still on the trucK?
Nov 17, 2007 at 3:56 PM
BLACKOP555
  • 10,386 POSTS
if you can get the truck there then yes, they should be able to test it seing they are a auto parts store!
Nov 18, 2007 at 1:22 AM
JASONMICHEL
  • 17 POSTS
is it possible the PCM is bad? or the wrong one? The orginal engine was a 302, it now has a 351. How can i tell...i took it to a repair shop and the PCM wouldn't power up their scanner
Nov 20, 2007 at 2:55 AM
Suggested Repair
Test or replace the idle air control valve; the 90-degree style may not be serviceable. Scan for trouble codes and also check the MAF and coolant temperature sensors, which can cause a lean cold-idle condition. Because the engine was swapped from a 302 to a 351 and a shop scanner could not communicate with the PCM, confirm the correct PCM and calibration if codes cannot be retrieved.
Conversation Summary
A 1992 Ford F-150 with a 5.8L that replaced the original 302 starts poorly when cold, needs throttle to stay running, and idles roughly until warm. It also misses at low speed and has a check engine light. Plugs were white with some incorrect gaps; plugs, wires, cap, rotor, and air filter were replaced without curing the surge and rough idle. The IAC had been unplugged: connected, idle was smooth but stuck near 1500 rpm; disconnected, idle dropped but ran rough and set the light. Experts advised testing or replacing the non-serviceable IAC, scanning codes, and checking the MAF and coolant temperature sensors. The PCM communication issue after the engine swap was not resolved in the thread.
