I have a 1990 ford f-150 302 motor, what model year will switch out with the 1990
May 30, 2007 at 6:20 AM
For an exact match, use a 1987-1992 302 with EEC-IV speed-density injection and knock-sensor provisions. A 1993-1995 roller-cam 302 can also be a near plug-and-play upgrade; 1996 and later engines use a different EEC-V mass-air system.
The owner of a 1990 Ford F-150 with a 302 asked which model years will interchange. The expert said 302 short blocks from 1969-2000 are essentially the same, but 1987-1992 engines best match the truck's EEC-IV speed-density system and knock sensor. A 1993-1995 roller-cam 302 can also work and is peppier, while 1996 and later engines use a different mass-air system.
