1990 Ford F-150 302 Motor Swap
SCOTTWRIGHT
I have a 1990 ford f-150 302 motor, what model year will switch out with the 1990
May 30, 2007 at 6:20 AM
INDYUKE
  • 416 POSTS
Yikes! That's a loaded question. What do you want in your motor? All 302 short blocks are essentially the same. You can pick anything from 1969 to 2000. The 1986 302 made the most power at 225hp.
If you want an exact match, the choose a motor from 1987 to 1992. Those all run the EEC-IV speed density fuel injection system (your truck), and are already drilled for the knock sensor... which your truck has.
The years 1993 to 1995 run a roller camshaft (and the EEC-IV system), which to be honest is a much better cam and it makes a previously so-so motor a bit more peppy. Years 1996 and beyond run the roller cam, but they have the EEC-V mass air system which is different than what you have.
I just replaced a 302 in a 1991 f-150, the owner chose a 1994 302 to replace it because it had the roller cam. Except for the cam, everything else was identical. Plug and play. Hope this helps.
Jun 10, 2007 at 5:52 PM
Suggested Repair
For an exact match, use a 1987-1992 302 with EEC-IV speed-density injection and knock-sensor provisions. A 1993-1995 roller-cam 302 can also be a near plug-and-play upgrade; 1996 and later engines use a different EEC-V mass-air system.
Conversation Summary
The owner of a 1990 Ford F-150 with a 302 asked which model years will interchange. The expert said 302 short blocks from 1969-2000 are essentially the same, but 1987-1992 engines best match the truck's EEC-IV speed-density system and knock sensor. A 1993-1995 roller-cam 302 can also work and is peppier, while 1996 and later engines use a different mass-air system.
