1999 Ford F-150 Blower Relay Burnout
Check intake air system for leaks, obstructions and damage. check the pcv system to make sure all is hooked up properly, check for any vacuum issues, broken lines etc.. check the maf sensor, I would remove it from the car, make sure electrical connectors are in good shape and clean.. look inside the maf, there's usually a screen in the horn, on some if you look carefully you can see the tiny resistor wires that monitor the air flow,, some are accessible enough that you can GENTLY wipe them off with a qtip and alcohol, sometimes they get dirty, well not really dirty in the dirt sense, but a film-type coating.. could aso be egr-related,, fuel pressure issues, or even the pcm if all other avenues have been diagnosed out,,If no luck with any of the above, issue may require assistance of the dealer or other qualified people, some of the testing of this problem requires specialized equipment and knowledge. As for the other a\c related problems, I don't believe these have any relation to above issues, possibly the blower motor is drawing too many amps and damaging the relays,, Do you have manual a\c or the eatc system?? The eatc system has the capability of self-diagnosing a lot of it's own problems.. on the manual system, it could be the blower switch itself, by relay I assume you mean the resistor bank??
Suggested Repair
Treat the issues separately. P0171 and P0174 are lean fuel-trim codes on both banks; check intake leaks, PCV and vacuum lines, MAF connectors and cleanliness, EGR, and fuel pressure. The MAF is not causing the blower relay to fail. For repeated relay failure on high, check whether the blower motor is drawing excessive current and inspect the blower resistor or switch, noting whether the system is manual or electronic automatic temperature control.
Conversation Summary
A 1999 Ford F-150 lost the A/C blower on high, the check engine light came on, and a replacement relay burned out again on high. The owner asked whether the mass airflow sensor could cause the relay failure. Codes P0171 and P0174 were retrieved. The expert said those codes concern fuel trim on both banks and are unrelated to the blower, recommending checks of intake leaks, PCV, vacuum lines, the MAF, EGR, and fuel pressure. The blower problem may instead be excessive motor current or a faulty resistor or blower switch.
