rear drive shaft seal is leaking
FORD F-150
MICSHIREY
sirs, I have a 1994 ford f150 V6 4.9 engine 4x4 with 110000 miles on it the rear drive shaft seal is leakinng how can i fix it. and is it a proplem that the average guy could fix thank you in advance for the timely help
Feb 12, 2007 at 5:20 AM
BOOTDOG
  • 665 POSTS
are you talking about the pinion seal? if so, you'll need to remove the drive shaft from the rear and move out of your way. remove the pinion nut, pull out the old seal, you can use either a pry bar or even a flat tip screwdriver. when installing make sure not to damage the new seal. lightly tap on the seal with a hammer or dead blow hammer until flush, then reinstall the pinion nut and drive shaft. don't forget to top of the 90/w oil. hope the info helps.
Feb 12, 2007 at 8:07 AM
