1990 Ford F-150 Coolant Overflow
LITHEON
I have a 1990 ford f-150 2 wheel drive 5.0 v-8 with 116000 i had the anti-freeze replaced the water pump replaced and the thermostat and thru the recovery reservior it fills up with anti-freeze and overflows why is that and is it a good idea to replace the the raditor
Feb 25, 2007 at 2:13 AM
SERVICE WRITER
  • 9,123 POSTS
The system may be overfull, there may be a restriction, or there may be a head gasket issue. Does it overheat?
Feb 25, 2007 at 4:00 AM
LITHEON
no it doesnt oveheat the temp gauge stays in the normal range
Feb 25, 2007 at 4:45 AM
SERVICE WRITER
  • 9,123 POSTS
It sounds like the system is just seeking it's level.
Feb 25, 2007 at 7:01 AM
ADRIANTHOMSON
buy something like rad weld you should be able to seal the leak and then clean all your pipes aswel
Feb 25, 2007 at 9:26 AM
SERVICE WRITER
  • 9,123 POSTS
[quote:f209f2fab9="adrianthomson"]buy something like rad weld you should be able to seal the leak and then clean all your pipes aswel[/quote:f209f2fab9]
I must have missed the part about the rad leaking. :?
Feb 25, 2007 at 9:45 AM
LITHEON
i thought about a leak too but its not leaking i had my mechanic check it out when he flushed it out but when i look down in the raditor it looks like the is alot of rust and scale in it so would it be a good idea to replace the raditor
Feb 25, 2007 at 10:30 AM
SERVICE WRITER
  • 9,123 POSTS
It won't hurt to replace, but If it isn't plugged or leaking, I wouldn't.
Feb 25, 2007 at 10:35 AM
Suggested Repair
Do not replace the radiator only because of rust or scale if it is not plugged or leaking. Confirm the cooling system is not overfilled; overflow into the recovery tank without overheating can mean the system is finding its level. Recheck for a restriction if the overflow continues.
Conversation Summary
The owner of a 1990 Ford F-150 5.0 said coolant fills and overflows the recovery reservoir after antifreeze, water pump, and thermostat service. The truck does not overheat, and a mechanic found no leak, though the owner saw rust and scale in the radiator. The expert said the system may be overfull, restricted, or have a head-gasket issue, then concluded it was likely seeking its level and advised against replacing the radiator unless it is plugged or leaking.
