Ok...here we go...now, I do have to un-loosen the ac coil to get to the 2 radiator bolts on the left...here's my problem...there are 2 ac coil bolts that are perpendicular on the left housing of the ac unit....just low enough, out of reach to use a 10mm wrench...and I cant use a socket wrench because it's too tight...that's why I was wondering if I had to take out the whole universal black grill that houses the lights...unless there is an easier way to get to the two small bolts on the ac coil...of course the coil sits directly in front of the two bolts on the radiator.
Jul 7, 2007 at 11:50 PM
