Poor Gas Mileage for my F150
DZTOYZ
  • 5 POSTS
no matter what i seem to do my 4x4 F150 is getting terrible gas mileage any ideas?
Sep 22, 2007 at 2:05 AM
INDYUKE
  • 416 POSTS
What year is the vehicle? Engine type?
Sep 22, 2007 at 2:24 PM
DZTOYZ
  • 5 POSTS
it is a 1992, engine type is a 5.0 EFI
I have racked my brain trying to figure it out
Thank you for the reply to my question
Sep 23, 2007 at 2:32 PM
INDYUKE
  • 416 POSTS
What type of transmission? How many miles on the motor?
What kind of gas mileage are you getting? For a 1992 F-150, 5.0L with average miles, I've seen them get as high as 17-19mpg on the highway with a manual trans... and as low as 10-13mpg.
Sep 24, 2007 at 8:41 AM
DZTOYZ
  • 5 POSTS
It is an automatic 4x4 and i keep the lockouts in freewheel, it has 100,000 or less,
thank you
Sep 25, 2007 at 1:49 PM
INDYUKE
  • 416 POSTS
If you have the C6 transmission, then I would expect you to get a lower mpg reading. It has no overdrive, and 1st is geared really high, so it takes some revs to get the truck going.
The AOD and E4OD trannys both have overdrive, which will make a difference on the highway. Unless you use it all the time, the 4x4 doesn't make that much of a difference these days, they're not as heavy as they used to be.
A 4x2 F-150, five speed manual coupled to a I300 will get you the best mpg... somewhere in the high teens. With your setup you can expect somehere around 13-17mpg, depending on driving style and where you drive.
Is there anything else you can tell us about the truck? Has it been running bad? Is this a problem that has become significantly more noticable recently? Check engine light on? Anything you can tell us could give a clue. Let us know.
Sep 27, 2007 at 3:24 AM
DZTOYZ
  • 5 POSTS
so i'm pretty well lookin at poor gas mileage then right?
well thank you for the info
Sep 27, 2007 at 1:28 PM
INDYUKE
  • 416 POSTS
Not necessarily. What are you getting for fuel economy? If you are getting in the mid teens, I think that's pretty respectable for a full size pickup. If you are getting in the high teens, that's downright crazy good, because a lot of small pickups with small V6's don't even get that kind of fuel economy.
But if you're getting only 10mpg with the setup you have, then I would start sniffing around for a possible cause. Low rear end gearing? Worn out engine? Lot of city driving? Everything plays a part. I hope this helps. Don't settle for unreasonably poor fuel economy. Even a Hummer gets 8-10mpg.
Sep 28, 2007 at 3:12 AM
DZTOYZ
  • 5 POSTS
yes it does help, I really love this truck and want to drive it more but with gas prices soaring it just sits.
Thank you very much I really appreciate the info!
Oct 8, 2007 at 1:45 PM
