P0354 cant find bad coil
JHNSNBRDLY
f150 ford 1999 180000ml 5.4L the code i got from the diagnostic is P0354 but i dont know which ignition coil is D. my truck is misfiring mosty when i put it in drive and i would like to know if it is the coil or something else. the code said P0354 ignition coil D primary/sencondary circuit malfuntion thank you[img:250957b8f9]http://www.2carpros.com/forum/automotive_pictures/82440_DSC00259_1.jpg[/img:250957b8f9]
Jun 28, 2007 at 7:04 AM
98RANGERXLT
  • 301 POSTS
Your engine has whats called coil on plugs for every spark plug there is a coil. Here is a guide to help you find the coil that is not working
Jun 28, 2007 at 1:02 PM
BRADTLEW
I've had a similar problem as many people with the misfiring of a cylinder, when i pull the code, PO354, coil D malfunction, how does this correlate to the cylinder number?? I have yet to find anything, on the internet anyways, showing me COP wiring diagram.
Apr 3, 2019 at 5:29 AM (Merged)
BRADTLEW
Apparently the code reader i have does in fact just list cyclinders 1-8 as A-H, so D, cylinder 4, had a bad coild pack and fouled plug. replaced and works fine now.
