oil in breather
FORD F-150
BERNARDINO TREVINO
I have a 2003 Ford F-150 with a 4.2L engine and 53,000 miles.The engine sounds great and there is no engine light on but i noticed that motor oil is coming out of the breather (air filter and canister). What could be causing this?
Nov 28, 2007 at 12:22 AM
INDYUKE
  • 416 POSTS
Either plugged up PCV system, or a PCV system that can't keep up with the amount of blowby the engine is producing. Guessing that your engine is still tight because of the low miles, i would say the PCV valve is probably plugged up.
Dec 4, 2007 at 4:06 PM
