Odometer display
SMITHLREG
  • FORD F-150
Ihave a 1999 F150 xlt 4x4 supercab with 114 kms with a 4.8 v8.
The digital odometer display sometimes stays blank then will come on after a bit. Is this a fuse problem and if so I couldn't locate which fuse controls this funtion
Monday, September 10th, 2007 AT 9:02 PM
SMITHLREG
My 1999 F150 xlt 4x4 doesnt have any hard shifting problems
Tuesday, September 11th, 2007 AT 7:43 PM
SMITHLREG
Thanks for the help, is this a difficult fix to repair the instrument cluster?
Wednesday, September 12th, 2007 AT 8:18 PM
CRAWDOOGIE
This is a common problem with 1999 f-150. The problem was worse when the truck was cold and would usually go away as the truck warmed up. The odometer going off and on is caused by a cracked solder joint on the instrument panel circuit board.
If you have access to a soldering iron then you can fix it yourself and it won't cost you a dime. (Well maybe a dime to pay for the solder used.)
Tuesday, November 13th, 2007 AT 9:53 PM
