1991 Ford F-150 Shakes Under Acceleration
NOCKAHOMA
I made a donation...not sure how you track that. I own a 1991 F-150 with a 5.8 liter V-8 with 98k miles. About a month a ago it started to shake when I hit the gas. The shake/shimmy is pretty obvious. Feels like the truck is going to shake apart. When it idols there is no shake. I was told by a friend that this is the motor mounts. The shake stops when I take my foot off the gas going down the road. Does that sound like the motor mounts? if so, how hard is it to fix/replace them?
Mar 23, 2007 at 11:12 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds more like a carrier bearing or a universal joint on the driveshaft. If you hold the driveshaft with one hand and the yoke with the other you can twist the driveshaft and see if any movement is present in the driveshaft.
Mar 23, 2007 at 11:17 AM
Suggested Repair
Inspect the driveshaft carrier bearing and universal joints for play by holding the driveshaft and yoke and twisting them against each other. Replace a worn U-joint or carrier bearing if movement is found.
Conversation Summary
The owner of a 1991 Ford F-150 with a 5.8L V-8 reports shaking under acceleration that stops when the throttle is released and is absent at idle. A friend suggested motor mounts, but the expert suspects a worn carrier bearing or driveshaft U-joint and recommends checking for play by twisting the driveshaft relative to the yoke.
