loud truck
BAKESTEAK
  • 5 POSTS
1984 ford f150 w/ 150,000 mi had n exhaust leak. I changed the exhaust manifold gasket and when i started it up it was loud as ever. And now when i start it it runs very loud and will shut off if left idling. I had to take the carberator off to get to the maniflod and i was wondering if that could have something to do with it. It sounds like more than an exhaust leak but im fairly new to this stuff so i dont know. i would appreciate any help i coud get. THANX
Mar 29, 2007 at 12:18 PM
MERLIN2021
  • 17,250 POSTS
check you egr valve! may have rotted off the holding block...
Mar 29, 2007 at 12:42 PM
BAKESTEAK
  • 5 POSTS
how do i check the egr valve. i took it off to see if there was anythign obvious but i didnt notice anything. i did pull a little piece of round burnt up steel wool looking stuff. thanks for the reply
Mar 30, 2007 at 7:51 AM
MERLIN2021
  • 17,250 POSTS
where did you find the steel wool? in the egr passage? If so get a steel coathanger and clear it out right to the throttle...But if the egr shown no signs of rotting out its not the reason for the exhaust noise! Get under the truck and check the converter...Air tube may be leaking, if it has one. But the only reason for loud exhaust noises is a loudy noisy exhaust!
Mar 30, 2007 at 9:26 AM
BAKESTEAK
  • 5 POSTS
i found the steel wool looking stuff in the brass colored cylinder that surrounds the actual valve. i assume that if the egr valve was startign to rot out it would be obvious. i thnk the problem is in either the exhaust manifold or the intake manifold becasue those are the only two parts i removed. or the carberator. i dont know if i forgot to put something back on or what but i have been messing with this truck for about a week now and it just seems to be getting worse. is it an absolute necessity that i torque the bolts holding the manifolds on to the specifications because i did not. is there anything in the carb that could make my truck loud or does it pretty much have to be the exhaust? thanks again for all the help
Mar 30, 2007 at 11:22 AM
MCFERRANCE
  • 100 POSTS
There may be a exhaust donut where the pipe bolts to the manifold that is leaking. Did you take the intake manifold off as well? Is this a 6 cylinder engine? Did you make sure to clean ALL of the old gaskets off and inspect the mating surfaces?
It is important to torque the bolts and in proper sequence as per the service manual.
Mar 30, 2007 at 1:39 PM
BAKESTEAK
  • 5 POSTS
i did not do any of those things. i didnt think it was the donut because when i pulled the pipe off it didi not have a donut in it and it was not leaking from there but i guess it couldnt hurt to put one on. i didnt take the manifold completely off, i just pulled it away from the engine, pulled the old gasket out and sli the new one in. i didnt torque the bolts properly or clean the surface either. i didnt know the stupid thing could be so sensitive. i guess that is probably where my problem is. thanks for the info.
Mar 31, 2007 at 1:52 AM
MCFERRANCE
  • 100 POSTS
Your particular application may not use a donut. But if any of the gasket material was left intact, it wouldn't properly seal whether torqued correctly or not.
Also, you can usually re-use the carb. base gasket, but if it doesn't seal properly, it will cause a vaccuum leak, poor idling, and stalling.
Mar 31, 2007 at 1:47 PM
BAKESTEAK
  • 5 POSTS
i got it all straightened out. there was a little piece of the old gasket left on the manifold. i didnt know that it would make such a difference. thanks for all the help. ill look you up next time i have to get my truck inspected.
Apr 1, 2007 at 1:40 PM
