Hi, Your problem maybe your speedometer gear on your speed sensor. It maybe chewed up. Try replacing it and see waht happens. If it does it again then you may need to go back to your original speedo gear (stock). If you have a speedo cable, check to see if its binding or if the actual cable is broken inside.
SPONSORED LINKS
Tuesday, April 6th, 2021 AT 6:18 PM
