Wayne-Oakdale, MN
2000 Ford Focus Valve Seat Damage
Wayne-Oakdale, MN
When you say air was injected into #2 cylinder, i presume you speak of a cylinder leak down test? Don't be alarmed by air escaping from the oil dipstick tube, thats normal whether the cylinder is damaged or not because what you are measuring is the percentage of pressure that cylinder will hold. Always some will go into the crankcase past the rings during the test.
What you should be concerned about is that air escapes out of #3 cylinder. If air doesn't escape from any other cylinder, i would consider the possibility of a blown head gasket between #2 and #3 cylinders, which is an inexpensive repair compared to replacing the entire engine.
Which is why i think it's wise to wait for more information after the head has been removed. I hope this helps.
Wait until the head is off and the mechanic is able to take a look at it, especially the valves, piston and cylinder wall.
If the rings are shot, you will have score marks in the cylinder wall. If you broke your timing belt, the valve(s) will be damaged as well as the piston(s). There will be no questions once you're able to see it. Even a blown head gasket leaves evidence.
Hello...yes, I have called every salvage yard within 100 miles of my area (Minneapolis/St. Paul) and not one is to be found. I need the harder to find "P' Vin number engine-there are a few "3's" out there. So, I put a request nationwide and have gotten 4 or 5 replies from what turned out to be "brokers"- all of whom had countless complaints posted about them - some really terrible. I almost gave my money to one of them who I learned has operated under several different names and scammed everyone they came in contact with. I never dreamed this could be so difficult, but in my case, it honestly has.
Suggested Repair
The head inspection confirmed that the #2 intake valve seat broke and damaged the head and piston. Compare the quoted head-and-piston repair with a used or remanufactured engine, and ask the mechanic whether a more common compatible engine could reduce cost and availability problems.
Conversation Summary
A 2000 Ford Focus with 65,000 miles developed loud metallic knocking and no compression in cylinder #2. Air from that cylinder also entered cylinder #3. After removing the head, the mechanic found a broken #2 intake valve seat that damaged the surrounding head area and scarred the piston. Repair options were a new head and piston, a used engine, or a remanufactured engine. Experts advised waiting for the visual inspection and then comparing costs, including checking salvage yards and asking whether a more common compatible engine could be installed.
