2001 Ford F150, 102000 miles, 4wd, 5.4 L V8
I first had a problem with the ignition solenoid. When it would get too hot, I could not start my truck. I replaced it. Simultaneously with the replacement, my truck started having electrical problems. While driving, my systems started cutting out one by one, first the radio, then the gauge cluster, then power windows, then more vital parts, like the fuel pump and/or O2 sensors, etc. I paid a guy 460 dollars to replace my starter, battery, and tell me a fuse was missing (which I didn't believe). After the new battery, my truck drove 35 miles to work this morning, then half way back, it was deja vu. One by one my electrical systems cut out, and eventually the truck stalled out. The battery was dead when I tried to restart. After a while, the battery did have some charge to it, but within 3 hours, not enough to start the truck. The radio and other functions came back with the key turned in the reverse direction. While at the shop last week, the mechanic said a 0.2 volt draw on the battery initiated when the driver side door closed. The alternator idea seems possible, but what is your opinion? I am near wit's end! Thanks for your help!
Sep 7, 2007 at 4:41 PM
