Ignition will not turn
H0MER0
1998 Ford F150 4WD -100,000 miles- V8 6L
The ignition will not turn with the key in it. the steering wheel has been turned so far that ti is locked into position. How do I replace the ignition switch?
Jul 23, 2007 at 3:18 AM
MUSTANG43201
  • 5 POSTS
[quote:ca295e39dd="h0mer0"]1998 Ford F150 4WD -100,000 miles- V8 6L
The ignition will not turn with the key in it. the steering wheel has been turned so far that ti is locked into position. How do I replace the ignition switch?[/quote:ca295e39dd]Take the tension of the lock by turning the wheel1/4 inch in either direction...The key should turn then.
Aug 24, 2007 at 1:47 PM
LOGIC
nope wrong answere , try again, thats the first thing people do, wtf , you guys *****s??
Jan 1, 2011 at 9:47 AM
