I tried to get my truck a required emissions test to renew my sticker and the check engine light was on so they could not perform the emissions test until the problem was fixed. I took it in to have them run the codes and this is what they came up with:
Test drive revealed MIL Light trans slow to up shift
998- Undefined
122 TP Sensor Voltage Low
542 Fuel Pum secondary circuit failure
Inspected TP switch wiring- ok swept on scan tool shows drop out
This is only my secondary vehicle and I do not want to spend an arm and a leg repairing it.
What would you guys recommend having done to get the check engine light to go off and for it to pass emissions test so that I can quit driving with expired tags. :Wink:
SPONSORED LINKS
Saturday, July 7th, 2007 AT 2:39 AM
