2000 Ford F-150 No Heat or AC
JAMES ERICKSON
I have a 2000 Ford F150 4wheel drive with about 80,000 miles. My heating and air conditioning have both stopped working. Ive gone through the fuses and there ok. What can I do. It has a V8
Mar 14, 2007 at 10:41 PM
BHUGG
  • 157 POSTS
Check under the hood for another fuse box. There you will find another fuse for the blower and also a blower relay. Check both of those.
Mar 18, 2007 at 5:32 PM
Suggested Repair
Check the underhood fuse box for the blower fuse and the blower relay, and test or replace either if faulty.
Conversation Summary
The owner of a 2000 Ford F-150 with a V8 reports that both heat and air conditioning stopped working after checking the fuses. The expert advises checking the underhood fuse box for a separate blower fuse and the blower relay.
