I have a 2004 f150 5.4 4x4 with 53000 miles on it. 5 months ago it died driving down the road {1 day only} Then ran fine until 3 days ago. Started up at low and high speeds. Will die maybe several times then all at once takes off and runs like a champ. It finally gave a p1235 code. Fuel pressure is at 45.3lbs but that was when it was running normal. Could it be a pump relay or inertia relay unless they are the same? Please help. THANKS
May 23, 2007 at 3:37 PM
