1994 Ford F-150 Fuel Pump Won't Engage
GEOBOB314
I have a 1994 F-150 4x4 with 190K miles and dual tanks The front tank fuel pump won't engage(no noise when I turn key) but the rear does(make noise) but won't start the truck. The front worked until today and I have never used the rear tank until I tried today. Both have fuel but the rear might be contaminated through idleness (or unstable) Any thoughts other than replace tank?
Apr 28, 2007 at 9:39 AM
BLACKOP555
  • 10,386 POSTS
drop the tank and take out the pump have it tested to see if it runs. if all is well disconect line before the fuel filter and if gas comes out there then you know it is either the fuel filter or something engine related. pumps have the chance of burning up if they run out of gas as they are gas cooled.
Apr 28, 2007 at 1:02 PM
MERLIN2021
  • 17,250 POSTS
could also be the switch to change the tanks over from one to the other...or wiring problem in that circuit.
Apr 28, 2007 at 2:18 PM
Suggested Repair
Drop the tank and have the front fuel pump tested. If it runs, disconnect the line before the fuel filter to see whether fuel reaches that point; if it does, check the filter or an engine-side fuel issue. Also inspect the tank selector switch and its wiring. Fuel pumps can fail if run dry because they are cooled by fuel.
Conversation Summary
The owner of a 1994 Ford F-150 4x4 with dual tanks says the front fuel pump no longer engages, while the unused rear tank pump runs but will not start the truck. Both tanks have fuel, and the rear fuel may be contaminated from sitting. Experts recommend testing the pump, checking fuel delivery before the filter, and inspecting the tank selector switch and related wiring.
