fuel pump
DKSIVERTJR
I have a 1992 ford f-150 . When you turn the ignition switch on the checkengine light comes on and the fuel pump runs continuosly,which makes the motor flood out . After about a half hour of the engine running the light goes out and seems to run a little better.
Nov 26, 2007 at 10:22 AM
BMRFIXIT
  • 19,053 POSTS
[quote:1b07e1aff7="dksivertjr"]I have a 1992 ford f-150 . When you turn the ignition switch on the checkengine light comes on and the fuel pump runs continuosly,which makes the motor flood out . After about a half hour of the engine running the light goes out and seems to run a little better.[/quote:1b07e1aff7]
check replace fuel pump relay try if you can to get the codes
Nov 26, 2007 at 12:56 PM
