Front Brake squeaks and grinds on light breaking
KBURGTOR
I have a 2005 F-150 crew cab with a 5.4 L V8. It has 23,000 miles.
When I stop with light brake pressure applied the right front break squeaks lightly and at times makes a little grinding sound.
I pulled off the wheel and looked at the rotor, which has no deep groves or marks on either side. I looked at the thickness of the break pads and both inner and outer are thick with very little wear.
What could be causing the squeaking and grinding sound when applying light break pressure?
This does not occur with hard braking.
Sep 26, 2007 at 1:00 AM
  • 75,988 POSTS
Your piston seal is not pulling back the piston far enough when its moving its self adjusting. The seal is not only there to prevent leakage that's its other purpose flex it back away from the rotor.
Sep 26, 2007 at 1:18 AM
