Ford F-150
JONESY63456
  • 1915 FORD F-150
I have a 1996 Ford F-150 with double tanks it cuts out and dies sometimes When I try to restart it it's almost like it has water in the gas it tries to backfire. I tried different gas in the front but it still did the same thing. When it does restart it runs about five minutes and then cuts out again if you keep the gas pedel down it won't die any suggestions
Saturday, October 6th, 2007 AT 3:00 PM
JAY6647
  • 17 POSTS
Sound like you might have a air/fuel metering problem. Your engine may be running lean possibily because of a dirty or malfunctioning MAF(mass air flow sensor). There are may ways to diagnose a faulty MAF sensor but they all require diagnosistic tools & a good understanding of the fuel delivery system. What clued me in on this problem is when you keep your gas pedal down (WOT -wide open throttle), the fuel system is tricked into a open loop & runs richer then the values it learned in closed loop which in turn keep the motor alive.
Hmmm. Sorry I got a bit technical!
When your MAF sensor is bad or dirty, it under estimates the amount of air going to the engine which mess up the amount of fuel being sent to the motor. So bottom line, it's starving for fuel!
You might want to try this, disconnect the connector to the MAF ( located after your air filter housing). If the problem gets better, replace the MAF. If not, bring it to a local repair facility. Have them check it out.
Hope this helps. Good luck!
Saturday, October 6th, 2007 AT 4:05 PM
