1994 Ford F-150 Low Charge Voltage
MADRUSSIAN
Thanks, I have a 94 F150 4x4 I replaced the altenator 3 times in past 2 weeks. I can not get over 12 volts of charge. checked every thing all looks good. i have 12.4 volts at battery and same from alt. to battery. what am i missing?
Mar 4, 2007 at 3:54 AM
  • 75,988 POSTS
[quote:07a10579ec="madrussian"]Thanks, I have a 94 F150 4x4 I replaced the altenator 3 times in past 2 weeks. I can not get over 12 volts of charge. checked every thing all looks good. i have 12.4 volts at battery and same from alt. to battery. what am i missing?[/quote:07a10579ec]
Check the wiring connector behind the alty whether it has power coming from the ignition switch.
Mar 4, 2007 at 1:25 PM
Suggested Repair
Check the wiring connector behind the alternator for power coming from the ignition switch.
Conversation Summary
The owner of a 1994 Ford F-150 4x4 replaced the alternator three times but still sees only about 12.4 volts at the battery and from the alternator. The expert advises checking the wiring connector behind the alternator for power from the ignition switch.
