1993 Ford F-150 Rear Tank Feeds Front
AMCC81
93 f150 I6 8'bed with the auxillary tank. i replaced the rear tank as both tanks leaked . i was going to only use the rear tank but now the rear tank pumps into the front one. is there a check valve on the front tank supply line? i noticed that both tanks supply and return into a common fuel block so this is the only out come i can think of since i didnt touch the front tank or set up im guessing a check valve failed . any suggestions PLEASE
Feb 27, 2007 at 9:33 AM
2CARPRO JACK
  • 11,533 POSTS
There was a Dealer installed check valve, part of an ongoing problem. If there is a fitting on the top of the tank that plugs onto the tank unit, then the fuel line plugs onto it, i have cleaned them out before , debris will stick them open.If you dont have the check valve,try Ford, but we havent been able to get them for a while now.If no valve, you will have to replace the fuel pump
Feb 28, 2007 at 12:05 AM
Suggested Repair
Clean the dealer-installed check valve fitting on top of the tank if debris is holding it open. If the check valve is missing or no longer available from Ford, replace the fuel pump.
Conversation Summary
On a 1993 Ford F-150 with dual tanks, the owner replaced the leaking rear tank and found fuel from the rear tank pumping into the front tank through the common supply and return block. The expert said a dealer-installed check valve was part of an ongoing problem and that debris can stick the fitting open, so it should be cleaned. If there is no check valve and Ford cannot supply one, the fuel pump must be replaced.
