i have a 1992 F-150 118,000 miles 4wd with a stick. When Im at a stop light or have the clutch pressed in the truck barely stays running. The voltage will drop and the truck bogs down then it goes back to normal. I the does this repeatedly when ever it idles. The truck does have an exhaust leak up front some where if the that helps at all.
May 24, 2007 at 9:36 PM
