1992 Ford F-150 Cylinders 2 and 5 Misfire
VINNYMAC89
i have a 1992 Ford F150 the motor runs but the number 2 and 5 cylinders do not fire correctly it has brand new rotor, cap, wires, spark plugs the history of the truck the problem came about from a ground for the fuel pumps and whatever else it was for disconnected and i think it shorted something out I'm not real sure so if you could help me that would be awsome[img:8ac05b1a30]http://www.2carpros.com/forum/automotive_pictures/99010_Picture_25_1.jpg[/img:8ac05b1a30]
Sep 9, 2007 at 3:15 PM
  • 75,988 POSTS
Do a compression check on 2/5-if its a MPFI investigate the injectors on 2/5-the outcome of the compression check should point you the direction to proceed-rings/valves/camshaft/lifters
Sep 9, 2007 at 7:56 PM
Suggested Repair
Perform a compression test on cylinders 2 and 5. If the engine is multiport fuel injected, also inspect the injectors for those cylinders. Use the compression results to decide whether to check rings, valves, the camshaft, or lifters.
Conversation Summary
The owner of a 1992 Ford F-150 says cylinders 2 and 5 do not fire correctly even after replacing the distributor cap, rotor, plug wires, and spark plugs. The problem began after a fuel-pump ground was disconnected and may have caused a short. The expert recommends a compression test on cylinders 2 and 5, injector checks if the engine is multiport injected, and further inspection of rings, valves, the camshaft, or lifters based on the results.
