Engine knocking
RUBERDUK
Hey guys, Im confused. I have a 1997 Ford F150 with 99,600 miles on it. I used it earlier this morning I had no problem. I went to use it like 10-11 hours later I had a knock in my motor. the more I give it gas the more it knocks and the louder it does... I had no signs of it starting, it just happened.. It has oil in it, I dont know.. Can you Help.... I have a 4.2 litre engine. I am looking it says it can be the egr valve.. I have been getting unusual amount steam in the mornings with high humidity coming from the exhaust... Other mornings its fine.. ?????
Jul 7, 2007 at 2:48 PM
JERRY HAMILTON
Usually when you engine starts knocking and gets louder as you give it gas your problem lies internally in the engine, probably a rod bearing. Does it sound like a metal to metal knocking? If so then 10 to 1 its a rod bearing. If a rod bearing goes out you will have no warning at all, it will just happen all of the sudden. You would probably be able to find a good used motor in a salvage yard at a cheaper price than to have the bearing replaced or that is true in a lot of cases.....you need to have checked out and shop around before you pay for anything.
Jul 16, 2007 at 7:13 AM
