1987 Ford F-150 Won't Fire After ECM Swap
DIRTYLITTLEMIND
1987 F150, 4.9 six, 4x4. I picked up a truck that some kids had tried to jump with the cables hooked up reverse polarity and the computer was burnt up. I bought a computer from an 89 f150, 4.9 six. Still seems like it isn't firing. Can someone tell me if this computer is compatible with the 87 and or any other electronics that may need replaced because of the reversed polarity?
Jan 24, 2006 at 9:30 PM
LOVESCARS
  • 359 POSTS
A salvage yard can tell you this. Need to have both computer numbers available.
Jan 25, 2006 at 1:10 AM
DIRTYLITTLEMIND
The old computer is numbered
E7TF-12A650-L2C
The new one is numbered
E9TF-12A650-DA
I was told that these are the only numbers needed to find out if the new one will work. Is there anyone who can let me know if the new one will work with this truck?
Feb 11, 2006 at 3:39 AM
LOVESCARS
  • 359 POSTS
those numbers don't maych so again unless this new computer is a superceded part call a parts department or salvage yard
Feb 11, 2006 at 1:04 PM
Suggested Repair
The replacement computer part number does not match the original. Unless it is a superseded part, confirm compatibility with a parts department or salvage yard before expecting it to work.
Conversation Summary
A 1987 F-150 4.9 was jump-started with reversed polarity, which burned the computer. A computer from a 1989 F-150 4.9 was installed, but the truck still would not fire. The original computer number was E7TF-12A650-L2C and the replacement was E9TF-12A650-DA. The expert said the numbers do not match and advised contacting a parts department or salvage yard unless the replacement is a superseded part.
