No Reverse - 2002 F-150 Supercrew
CHERYLSUE79
  • 2002 FORD F-150
My 2002 F150 Supercrew V8 w/auto transmission and 97000 miles will not go into reverse. The problem started when the overdrive light on the shifter started flashing. The next day I go to back the truck out of the driveway, when I put it into reverse it wouldn't move so I depressed the gas a little. The truck then jerked into reverse really hard. I put the truck back into park and turned it off because it scared me a little. Ever since then it won't go into reverse at all. I checked the tranny fluid after warming the engine up and the levels are fine, the fluid looks good and doesn't smell burnt. What is the problem? Any help will be appreciated. Thanks :D
Thursday, May 17th, 2007 AT 11:51 AM
AUTOPOP
  • 49 POSTS
Sounds like one of your transmission bend is broken, you probably only have first three forward speed.
Trans. Has to come out to service this.
Friday, May 18th, 2007 AT 1:02 PM
MERLIN2021
  • 17,250 POSTS
You might want to check the pump pressure.
Friday, May 18th, 2007 AT 1:23 PM
