1993 Ford F-150 EGR High Voltage
SWIFTY
I have a 1993 F-150 with 165,000 miles on a 302 motor.I run a self test on it because of poor fuel mileage. the test said egr valve closed high voltage can you tell what this means?
Feb 27, 2007 at 11:27 AM
TAURUSWHEEL
  • 718 POSTS
what code number did you get???? What type of egr system do you have???
Feb 27, 2007 at 11:43 AM
INDYUKE
  • 416 POSTS
The computer is complaining about the EGR sensor.
Double check the EGR sensor wiring and connections.
The EGR valve diaphragm could be punctured.
The sensor itself could be bad.
Those are a few suggestions. I hope this helps.
Feb 27, 2007 at 11:45 AM
Suggested Repair
Check the EGR sensor wiring and connections. Inspect the EGR valve diaphragm for a puncture, and test or replace the EGR sensor if those checks do not resolve the high-voltage closed reading.
Conversation Summary
The owner of a 1993 Ford F-150 with a 302 engine and poor fuel mileage ran a self-test that reported EGR valve closed high voltage. One expert asked for the code number and EGR system type. Another said the computer was complaining about the EGR sensor and suggested checking the sensor wiring and connections, a punctured EGR diaphragm, or a faulty sensor.
