Any suggestions would be appreciated
E150 Check Engine Light
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the intermittent warning diagnosed under the conditions that bring it on. Provide the earlier code if available and ask for testing of the EGR system before authorizing replacement.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Is intake air filter clean
Thanks for the reply
Discussion summary
A 1988 Ford E-150 illuminated its check-engine light under load but not at idle. The owner had previously obtained an EGR-related indication, cleaned the EGR valve and later found no codes with the available reader.
Reported outcome: No confirmed cause or successful repair was reported.
The exact earlier code and EGR test results were not supplied. Cleaning the valve and finding no later code did not establish why the warning returned under load.
