1996 Ford Probe P0421 P1506
The catalytic converter is no longer functioning properly
An oxygen sensor is not reading (functioning) properly
A spark plug is fouled.
Time to have the O2 sensor after the cat tested. It should show steady voltage (~200MV depending on the vehicle). If the voltage varies (100MV to 600MV) it is time to replace the cat. Have all the O2 senors tested while your at it.
P1506 Idle Air Control System Overspeed Error (Ford)
This DTC is set when the PCM detects engine idle speed that is greater than the desired rpm.
Causes.
IAC circuit short to GND
Damaged IAC valve
IAC valve stuck open
Vacuum leaks
Failed EVAP system
I would start out by cleaning the IAC valve and it's port.
Good luck and let us know.
any ideas?
Suggested Repair
For P1506, clean the idle air control valve and its port, and check for a stuck-open or damaged IAC, a short to ground, vacuum leaks, or an EVAP fault. For P0421, test the downstream oxygen sensor for a steady voltage around 200 mV; if it swings widely, replace the catalytic converter, and test the other oxygen sensors as well. If the fasteners look like Torx but will not seat, clear corrosion from the center before forcing them.
Conversation Summary
The owner of a 1996 Ford Probe with 75,000 miles reported codes P0421 and P1506 from an auto-parts scan. The expert said P0421 can indicate a failing catalytic converter, a faulty oxygen sensor, or a fouled spark plug, and advised testing the post-catalyst oxygen sensor and the other sensors. P1506 is an idle air control overspeed error; the suggested first step was cleaning the IAC valve and port, while also considering wiring, a stuck valve, vacuum leaks, or EVAP failure. The owner then asked about screws that appeared to be Torx but would not accept a bit, and the expert suggested corrosion in the center and cleaning it out.
