1996 Ford Probe P0421 P1506
DABRUGUY
Hi, I have some Check engine light codes that we got from the Test at Autozone, the car is a 1996 Ford Probe, with 75,000 miles on it. The codes are P0421 & P1506....
Feb 21, 2006 at 11:34 AM
PEPPERMRJ
  • 1,158 POSTS
PO421
The catalytic converter is no longer functioning properly
An oxygen sensor is not reading (functioning) properly
A spark plug is fouled.
Time to have the O2 sensor after the cat tested. It should show steady voltage (~200MV depending on the vehicle). If the voltage varies (100MV to 600MV) it is time to replace the cat. Have all the O2 senors tested while your at it.
P1506 Idle Air Control System Overspeed Error (Ford)
This DTC is set when the PCM detects engine idle speed that is greater than the desired rpm.
Causes.
IAC circuit short to GND
Damaged IAC valve
IAC valve stuck open
Vacuum leaks
Failed EVAP system
I would start out by cleaning the IAC valve and it's port.
Good luck and let us know.
Feb 22, 2006 at 11:23 AM
DABRUGUY
Hi when I look at this unit, it has two screws that look like TORX screws, but my torx wrenches won't work due to the srcew has a small spot in the middle which will not allow the torx wrench to fit into it, unless it is the phillips head screws I see on the unit,,, I just figured I would ask before I started ripping it apart
any ideas?
Mar 5, 2006 at 1:31 AM
PEPPERMRJ
  • 1,158 POSTS
10 year old screws can be a pain. My guess is that they are torx but with some corrosion in the center. Clean them out with a nail head or scratch awl tip. Use a magnifying glass if you are still uncertain as to their type. What unit are you removing?
Mar 5, 2006 at 2:19 AM
Suggested Repair
For P1506, clean the idle air control valve and its port, and check for a stuck-open or damaged IAC, a short to ground, vacuum leaks, or an EVAP fault. For P0421, test the downstream oxygen sensor for a steady voltage around 200 mV; if it swings widely, replace the catalytic converter, and test the other oxygen sensors as well. If the fasteners look like Torx but will not seat, clear corrosion from the center before forcing them.
Conversation Summary
The owner of a 1996 Ford Probe with 75,000 miles reported codes P0421 and P1506 from an auto-parts scan. The expert said P0421 can indicate a failing catalytic converter, a faulty oxygen sensor, or a fouled spark plug, and advised testing the post-catalyst oxygen sensor and the other sensors. P1506 is an idle air control overspeed error; the suggested first step was cleaning the IAC valve and port, while also considering wiring, a stuck valve, vacuum leaks, or EVAP failure. The owner then asked about screws that appeared to be Torx but would not accept a bit, and the expert suggested corrosion in the center and cleaning it out.
