1998 Ford F-150 Brake Pressure Switch
KAATT52000
I have a 1998 Ford F150 Clubcab. Does any one know where the brake pressure sensor switch is located?
Apr 11, 2006 at 1:28 PM
LOSONE
  • 1,616 POSTS
There is no brake pressure sensor sw that I know of except on an ABS system and it is part of the hydraulic module. The only brake sw that I know off is the brake light sw that is located at the top of the brake pedal. Let me know
Apr 12, 2006 at 5:54 AM
Suggested Repair
There is no separate brake pressure sensor switch except on an ABS system, where it is part of the hydraulic module. The brake light switch is located at the top of the brake pedal.
Conversation Summary
The owner of a 1998 Ford F-150 Club Cab asked where the brake pressure sensor switch is located. The expert said there is no separate brake pressure sensor switch except on an ABS system, where it is part of the hydraulic module, and that the only brake switch is the brake light switch at the top of the brake pedal.
