'91 F150 - Removal of power window unit
1991 FORD F-150
LHOWER
I have a 1991 Ford F150 XLT. The driver's side power window had stripped its gears in the regulator, or some such. I am trying to remove it for repair. I have the door panels off, and have pulled back the plastic dust seal. It appears that the mechanism is blind riveted to the inner door panel. Before I grind off these rivets to remove the motor/gearbox/regulator, I just want to make sure I am not missing anything. Is this the expected removal procedure (grinding or drilling out the pop rivets)? Or is there another means of removal? Thanks.
May 14, 2007 at 9:55 AM
UNCLE FESTER
  • 13 POSTS
Disconnect the battery ground.
Remove the door trim panel.
Disconnect the window motor wiring harness.
There are 2 dimples in the door panel, opposite the 2 concealed motor retaining bolts. Using a 1/2 in. (13mm) drill bit, drill out these dimples to gain access to the motor bolts. Be careful to avoid damage to the wires.
Remove the 3 motor mounting bolts.
Push the motor towards the outside of the door to disengage it from the gears. You'll have to support the window glass once the motor is disengaged.
Remove the motor from the door.
Installation is the reverse of removal. To avoid rusting in the drilled areas, prime and paint the exposed metal, or, cover the holes with waterproof body tape. Torque the motor mounting bolts to 50-85 inch lbs. (6-10 Nm). Make sure that the motor works properly before installing the trim panel.
May 14, 2007 at 11:17 AM
LHOWER
Thanks for the advise and tips. I will let you know what I find. My pickup is at my remote shop and I should get back to it this weekend.
Thanks again.
PS: It took a little time to get back into my "shop". Know knowing exactly what the problem was and not wanting to work partially in the blind, I opted to drill the blind rivets and remove the entire assembly. Repair was then easy and reassembly with short 1/4 bolts and lock nuts was easy.
Thanks for advice on both approaches. Now that I have the experience, the next time I will drill the door panel and just remove the motor.
Thanks again... and I will donate!
May 15, 2007 at 9:23 AM
