will not start suspect fuel problem?
TWORK
My 88 Ford F150 W/300 6 cyl eng will not start. Suspect fuel problem but
when fuel line was disconected it had no pressure. cahnged main fuel pump and still would not start. checked old pump and it works.
checked the wires with volt meter and no power.checked resistance and got a pos reading on both wires. has duel tanks but switching them does no good
Jan 15, 2006 at 12:17 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the reported loss of pump power and the dual-tank fuel-supply system diagnosed together before replacing more parts. Include the tank-switching valve suggested in the reply, without treating it as an established cause.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
  • 55,549 POSTS
these trucks had a problem with the switching valve not working and cutting all gas off. It is located between the two tanks at the frame rail.
Here is a guide as well to go over the basics if the valves checks out.
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
May 31, 2021 at 5:47 AM
Discussion summary
A 1988 Ford F-150 with a 300-cubic-inch six-cylinder engine and dual tanks would not start. The owner reported no fuel pressure and no power at the checked pump wires; replacing the main pump had not helped.
Reported outcome: No follow-up test results or successful repair were reported.
The reply proposed a switching-valve fault, but no test confirmed it. The owner's electrical findings and exact fuel-system configuration need verification.
Read the original discussion
