Huge change in fuel consumption?
17,500 MILES • V8 • 2WD • AUTOMATIC
NEDJA
  • 5 POSTS
Until recently,my gas millage was approximately 14.5m/gal.,but then suddenly dropped to 9.8m/g.The only difference is that i started pulling a 26'Traveling Trailer(Dry Weight 4650Lb).But,what is weird is that it does stay the same even when i am not pulling trailer.
I checked air filter and it is good.Oil,and oil filter were changed recently.Wonder,what could make it go so bad?
Oct 8, 2010 at 2:24 AM
DRCRANKNWRENCH
  • 3,380 POSTS
A few culprits for the change in fuel consumption could be; a leak in the exhaust near O2 sensor, a bad O2 sensor, catyltic converter needs replacement, needs general tune-up, ECU or sensor malfunction but 9 times out of ten it will be the MAF sensor
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
There are other things that aren't always part of general maintenance that can really affect fuel mileage such as dirty fuel injectors. Most injector cleaners do not do very much and are not capable of making partially clogged injectors free of deposits.
The fact that fuel consumption does not change in a, "not towing" situation is interesting. That makes me think more along the lines of a clogged converter or bad O2 sensor. I say this because they are things that get taxed when towing because they are dealing with more un-burnt fuel which makes them hotter than usual and can lead to failure.
Fords can sometimes take a little while for the computer to adjust when the load demand is different.
How long does your truck continue to have bad gas mileage after you stop towing?
Let me know and I will try to help.
Oct 8, 2010 at 2:46 AM
NEDJA
  • 5 POSTS
Thanks a lot for your quick response.It stays the same,ever since it started about a month ago.And i checked fuel consumption literally,by deviding the used gesoline with milage.I also do not see any worning lights,like Check Engine soon or else..
Oct 8, 2010 at 2:58 AM
DRCRANKNWRENCH
  • 3,380 POSTS
That is the right way to check fuel consumption.
With electrical system stuff, a warning light, especially in this situation, might not get lit. Even when a code reader is hooked up or you can sometimes use a shunt wire to pull codes, they don't always show up.
If the computer gets a signal from the O2 sensor that the mixture is lean, it will feed the system more gas. Even though the sensor has malfunctioned, the computer will not see it as a malfunction if it falls within a certain range. An exhaust leak will cause a lean condition and do the same thing. The O2 sensor might have failed and it is stuck at a certain voltage requesting the same amount of gas from the computer as when you were towing. I am mentioning this because I am thinking something is failing or failed while you were towing and got stuck to where it can no longer sense variations in mixture or load on the motor and it is sending the same signal to the computer.
I do not know everything. I am not sure that an O2 sensor can get stuck at a certain voltage and then continue to send that same signal creating your problem. From the O2 sensors I have some knowledge of, I believe it is possible.
Electrical problems are a process of elimination thing and you do sometimes have to buy parts that are either part of the problem or were not if you do the job yourself. The real diagnostic equipment is very expensive and only good repair shops have the best stuff. Even then it is still the same thing.
So let me know what you can. Maybe price out an O2 sensor if you have never replaced it as it might need it anyway especially if your going to be towing.
It will work out.
Oct 8, 2010 at 8:47 AM
NEDJA
  • 5 POSTS
Hi,DrCranknWrench
Thanks for all the help and interest in my problem.I also think it is O2,but i was puzzled because Check Enigine Light did not come on.I could change it but i do not know weather that would effect my warranty.So,even i do not like to take it in i will this time,and have them inspect it and make sure that that is the real problem.
I will let you know how everything works out!
Thanks again,Nick.
Oct 11, 2010 at 1:07 AM
DRCRANKNWRENCH
  • 3,380 POSTS
You are definately right to take it to the dealer. Normally, an O2 sensor is part of a full service, the type of service where high mileage maintenance items are replaced, so it would not affect warranty...but you would have to have a 100,000 mile warranty to worry about that.
The fact that a trouble light is not coming on is not unusual. Especially with electrical items, the problem is that they will fail slowly sometimes and until they are bad enough to fall out of specifications that the ECU will trip a code,so it won't throw a light, sometimes even a code reader won't catch it.
Only a dealer will have the type of diagnostic tools to catch that kind of stuff.
Let me know how it all works out.
Oct 11, 2010 at 1:40 PM
NEDJA
  • 5 POSTS
Hi DrCranknWrench,
I went to Ford and after a day of testing they are saying that nothing is wrong.But first,their service rep told me yeterday that something was wrong with Electronic Control Unitt and hey have had it reprogramed reprogramed.Today they are saying everything was OK,and i should try to use some better blend of gas.I think they just do not wanna officialy admit that ECU failed.
This is why i do not like to go there.
But i will fill it up today and after a few days i'll get the correct and accurate figure.
Thanks for all your help
Oct 15, 2010 at 7:02 AM
DRCRANKNWRENCH
  • 3,380 POSTS
It is certainly worth doing what they suggested so that they cannot throw it back at you later. I have had the same type of issue where the Tech could not replicate the problem and they blew me off.
It took a long time and I had to go to several dealerships before I got help.
A few things that I found that helped besides getting a second or third opinion are; checking the dealerships records of recalls and service bulletins. Their are Government web sites that keep track of safety related recalls, but do not keep track of much else.
Service bulletins are internal memos that dealerships use to help diagnose problems that are hard to find the source of the problem. It saves them time and money. They will also try not to help with these issues if they think the issue might not get covered when audited by a company rep.
So issues like yours are a high risk for them to fix as the parts are expensive and they might not get money for the job if the company rep. does not approve the repair upon review.
So, check recalls, service bulletins at some other dealerships and get a feel for the customer service provided. Larger dealerships are more likely to fix this type of issue.
Let me know how it goes as I will keep an eye on this link.
Oct 15, 2010 at 10:40 AM
NEDJA
  • 5 POSTS
Hi,DrCranknWrench
I just checked my gas millage on 120 miles of mostly city driving condition,and it looks like they did something to the truck.(...probably reprogramed ECU).It runs an average of 15.4 Miles/Gal which is very good.I just hope it does not go back to old trend later on.I'll check all those things you suggested as soon as i get a bit more time and thanks again on all your help!
Sincerely,Nick Najdanovic
Oct 18, 2010 at 1:21 AM
DRCRANKNWRENCH
  • 3,380 POSTS
That is great news! I am very happy to hear that you got it fixed without spending any money.
Defincately check around for recals and bulletins that you might not be aware of. They are part of the warranty you paid for and deserve to be fixed if your truck is affected by them. Another thing to remember while youo are doing this is sometimes they will retro-fit vehicles at the plant when a problem is found. They then keep track of the VIN numbers that the fix was put into and the vehicles that did not. So, a dealer might say that your truck is not affected. So, ask for the VIN numbers that the recall/bulletin are for.
I will keep an I on this post link and if you need anything else I am glad to help.
Take care.
Oct 18, 2010 at 4:01 AM
WPGMB
I found this artical very interesting, spent a long time searching as I have the same problem. Purchased my truck in summer 2010,in early October we went on a little vacation and went from 14L/100km city down to 12L\100km @ 19-20mpg highway. We brought our trailer home with us and it went up to 23L/100km, it has since dropped down to 21L city and 20L highway but has not return back to normal. The dealer service department told me that it was using more fuel because of the cold. That may be true ... but not 50% more fuel. Another dealer suggested different fuel. I have tried different fuel blends ... with no difference.
Mar 24, 2011 at 6:55 PM
DRCRANKNWRENCH
  • 3,380 POSTS
There is some truth that the gas is less efficient in winter as Ethanol is added. It actually has more potential energy than gas/petrol, but it depends on the motor. Some do better, some worse.
As far as towing goes, the computer does need some time in, "Hours Driven" to correct itself for best MPG and that happens faster if it is kept in tune.
I don't know if you are using the MPG meter on your dash display or not, but if you are, it is an average of MPG since it was last cleared out. So, it won't react quickly or tell the, "Real-Time" numbers.
Fill up the truck and let the pump turn it off, then write down how many gallons. Do it again and calculate it that way....unless you already
are.
The dealer is trying to use some truth, but you are right. The cold air is denser and the difference is not going to make it consume 50% more gas. If you went on vacation to the mountains or to an area with a large elevation change from your home, that will make things hard on the trucks' computer as it has to change so many parameters so fast.
Always get gas from a reputable station as the extra cost is worth it. Mobil/Exxon is one of the better ones as they put a detergent in the gas to keep the engine cleaner and they have higher standards for the amount of contaminants in fuel and are very precise with octane ratings. Using the same gas is easier on your Rig as well. The computer does not have to work as much and you can depend on more consistency so the next time your dealer say, "It is that cheap gas you bought one time". You can reply, " No sir, I always use the recommended octane from the same gas station".
Let me know if you need anything else. However, I will be unavailable the next 4 weeks and I will probably loose track of posts that I am working with like this one. You can send me a PM, if it is working, or the team of experts here is a very rare thing. They come from all over the world and we help each other all the time. So, if you can't find me, someone on the team will respond and help you out.
Take Care
Dr. C
Apr 11, 2011 at 2:17 PM
RKA
I purchsased a new 2010 f-150, 5.3 L V-8 back in Sept. 09. the estimated average gas mileage on sticker was 14C & 18H. The best I have ever gotten is 14.5 and currently getting 13.7. These are all HWY miles driving speed limit. Any thoughts as to why such bad mileage?
Sep 3, 2020 at 7:19 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, here is what I have found on a lot of vehicles....
If you are using the low octane gas you loose milage. First thing I would try is filling up and purchase an Octane Booster and see what happen. In my personal vehicle I have noticed about a 4 - 6 mile gain.
Also have you changed the Air Filter recently. A clogged filter will reduce air flow and create a richer air/fuel mixture.
Another cause and a lot of people don't realize is that Altitude can affect milage. And of course the manufacturers don't tell you that.
JD EDWIN
Exhaust got pulled off and now I put mufflers on it but o2 sensors are not working. so I unhooked them . it sounds like it only running on four cylinders and get about six miles to the gallon.
Sep 3, 2020 at 7:20 AM (Merged)
JOETECHPRO
  • 705 POSTS
Hey JD EDWIN,
The original exhaust was damaged so you replaced it?
You will need O2 sensors connected for the engine to run properly, the before catalytic converter O2 sensors are vital to correct engine running.
Are the O2 sensors you disconnected before or after the catalytic converter? If they are before the catalytic converter you will have to reconnect them and ensure they are working first.
The picture attached shows the before catalytic converter (stream 1) and after cat (stream 2).
Do you still have catalytic converters fitted?
Any more information would be great.
Regards, Joe
JD EDWIN
No, I do not have the catalytic converter. the 02 sensors are before the sensors. Is there anyway to make it run right without the catalytic converter on it?
JOETECHPRO
  • 705 POSTS
Hey JD EDWIN,
It will run okay without the catalytic converters but the O2 sensors that were fitted before the catalytic converters must be fitted to the new exhaust for the PCM to get data to adjust fueling.
Without the converters fitted you will have issues with emissions.
Regards, Joe
SKIYRYDER
When I stop at a light or stop sign the engine RPMs drop to 0 and the truck dies. Fuel consumption is also higher. Is this from bad gas, the fuel filter, or something in the computer system that controls fuel into the engine?
RACEFAN966
  • 5,029 POSTS
Ok is the check engine light on? Get back to me
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated
Is the CEL (check engine light) showing on the dash display ? .. this fault could be due to the IAC or MAF sensors or other control sensors ?? the vehicle should still be under warranty ?? have fords check this out for you !! hope this helps .. let me know
JGWJ5800
I own a 2007 f-150 5.4 triton v 8 I have 28000 mile tires are inflated correctly and all the little stuff is taken care of ie oil change ect. Ihave seen a reduction in mpg a slight miss at idle and sometime the oder of gas while at idle. I use to get 17mpg in town and 21.5 on hwy now 11mpg in town and 17 on hwy. thanks jim
MJR346
  • 132 POSTS
Usually unless the check engine light is on, I wouldn't suspect a engine issue.. Could be a fuel issue with many areas going to 10% ethanol or more and that is known to drop mileage hard
MIKE H R
  • 3,094 POSTS
There also may be some buildup of carbon in the throttle body clogging a air vent. If this is the case to clean it out Use some throttle body cleaner and try that. Available at most aiutomotive stores. Follow instruction when using it.
  • 16 POSTS
There are no codes. I did a live data read on the 02 sensors and Bank 1 and 2 upstream have fluctuating readings with a square up and down sign wave but Bank 1 and 2 downstream are reading 0.000. I would think 0 reading would show a check engine light are is this reading normal? I have 170,000 on the original 02 sensors so was thinking it might be time to replace.
Sep 3, 2020 at 7:21 AM (Merged)
  • 16 POSTS
Additional information: I drove around with live data and both bank 2's started giving readings. The sign waves where all over the place and at times flat lined.
MASTERWRENCH
  • 258 POSTS
A voltage reading of 0.00 on both downstream sensors is not what I would expect to see. Under normal conditions, the downstream will be a very close mirror image of the upstream just after the engine is started. After the engine runs for a short period of time and the catalytic converters have time to "light off", the downstream signal will begin to level off. An absolute reading of 0.00v is very unlikely and is very possible the result of worn sensors.
In your second post, you indicate "both bank 2's started giving readings". Do you mean both downstream sensors or the upstream and downstream on Bank 2?
  • 16 POSTS
Both downstream sensors started responding.
MASTERWRENCH
  • 258 POSTS
Okay, I'm with you. It's probably working normally then. You are correct, if there really was an issue(like both sensors unexpectedly stuck at 0.00v) it would definitely set a code. Are you sure your fuel economy drop off isn't just a result of the cooler temps and the seasonal switch to winter blend fuel? Have you changed anything on the vehicle recently such as a more aggressive tire tread or oversize tire? Some of those things can have a more significant effect on economy than some realize.
  • 16 POSTS
Haven't changed anything, truck is stock. The mileage drop off has been last 4-5 months. I was reading where 02's can become lazy and not throw a code causing a drop in fuel economy and with 170,000 miles on original 02's I thought it might be something to look into. The truck has been very well maintained.
  • 55,542 POSTS
If I can help out. I have seen the MAF sensor go bad causing this issue which will cause the O2 issue as well. I would replace the sensor with a new unit these are normal service items. Here is a guide to help walk you through the steps with instructions in the diagrams below to show you on your car:
Mass Air Flow Sensor - YC2Z12B579BARM $264.51
  • 16 POSTS
Thank you for the response, looking into to doing that.
NORDMEER
2002 F-150 4x4 Super Cab 4.6L V8
53,000 mi
Auto Trans
Tires 265 75 16 (Originals 245 75 16)
Bought the truck used through a non-Ford dealer and also purchased a warranty plan from the same dealer. The head leaked in January, and the dealer replaced the gasket. In March, it started to leak again, and they told me this time that the cylinder head itself was gone. They then installed a new head. Now the truck is low on power, and fuel consumption is up by 25%. On the highway, the tranny often shifts itself back into 2nd gear just to keep 65mi/hr on the hills. It was never like this before. I brought it back and they are now telling me that the problem is with the tires, that they're too big. They also said the truck needs to be "recalibrated" for the tire size. But its only one size (as stated above) and I had this tire size on the truck since last fall, and also the winter before, with no problems. Any ideas or suggestions are greatly appreciated. Thanks.
2CARPRO JACK
  • 11,533 POSTS
Has it set the check engine light? Sounds like they are trying to push it off on you.Take it back to them and demand that it be fixed correctly. That littel of a tire change wont kill hardly any power,just change the shift points.
NORDMEER
Thanks for the reply. Went back to challenge the dealer, and they finally gave in and sent the truck to Ford. Turns out 2 cylinders on the right side (same side as the new cylinder head) are 6% low on compression. Looks like I have a legit case. Again, appreciate the second opinion 2CarPro Jack!
2CARPRO JACK
  • 11,533 POSTS
Your welcome
