Instrument Cluster All gauges drop to zero and then return?
2009BIGBLUE
Electrical problem V8 Two Wheel Drive Automatic 37000 miles
Intermittent gauge operation. All gauges drop to zero and then return. Conditions: The vehicle is traveling on a straight and level dry paved road @ 55MPH. Ambient temp approx 57 degrees.
Not to unearth any "rabbit holes" to chase down but here are some additional observations that may or may not apply: Hear what sounded like clicking from behind or under the dash. I noticed the airbag light was lit on the instrument cluster when the needles dropped to zero.
Apr 27, 2010 at 4:00 AM
  • 55,676 POSTS
It sounds like you have a bad connection at the cluster. Please remove the connector at the rear of the cluster and reconnect, this will clean the connections and get the cluster working again.
Here is a wiring diagram so you can check the grounds and power supply to confirm.
Cheers, Ken
Jul 11, 2017 at 1:17 PM
