2007 Ford F150 no speedo or cruise control
45,000 MILES • V8 • 4WD • AUTOMATIC
STEVEFROMONTARIO
had my truck for 4 months ,got it used ,the speedo and cruise did work but just recently stopped. the mileage isnt increasing either, Is the speedo and odometer a drive cable or electronic? how would i find out if its been broken or disconnected somehow?
Oct 8, 2008 at 1:07 PM
RACEFAN966
  • 5,029 POSTS
There is no cable it is electronic. It is controled mostly by the Rabs valve on the rear end. Some call it a vehicle speed sensor. It is on the top of the rear end just to the left (drivers side) of the center it has a two wire connector on it. This could cause it. Hope this helps. I tried to find a picture of but couldn't. If you need one I will look today at work and try to find one.
Oct 9, 2008 at 2:11 AM
