MY AC DOES NOT WORK AFTER THE TEMP OUTSIDE REACHS 75 DEGREES, WHATS UP WITH THAT !
May 27, 2010 at 1:00 PM
✓Experienced Mechanic
When was the last time the system was charged?
May 28, 2010 at 5:58 PM
BURDEND
MEMBER
[quote:9ddeb08118="Jacobandnickolas"]When was the last time the system was charged?[/quote:9ddeb08118]
I charged it 2 wks ago, used about a lb. of r134 showing good pressure for the outdoor temp here (was 60 degrees and had 25 lbs. of pressure). this is with the system running.
May 29, 2010 at 6:50 AM
THat sounds good. Something tells me that the problem isn't the AC. When temps reach 75+ and it stopps working, does the compressor continue to cycle or does it just stop all together?
May 29, 2010 at 2:39 PM
BURDEND
MEMBER
[quote:6a79055763="Jacobandnickolas"]THat sounds good. Something tells me that the problem isn't the AC. When temps reach 75+ and it stopps working, does the compressor continue to cycle or does it just stop all together?[/quote:6a79055763]
