Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Ignition
Coil
Replace/Remove
2007 Ford F-150 my truck shakes
2007 FORD F-150
215,639 MILES • V8 • 2WD • AUTOMATIC
JEREMY ROBINSON
MEMBER
1 POST
my truck shakes alot but only when im sitting still. It does good on the road. I have changed my plugs and coil paks what else could it be?
Oct 20, 2010 at 10:11 AM
Experienced Mechanic
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Oct 20, 2010 at 11:34 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
