2006 Ford F150 whirring
119,000 MILES • V8 • 4WD • AUTOMATIC
MCK57
The Car Sound Problems section on this site indicates that a whirring noise could be the result of a failing differential gear. Would that cause the transmission to feel as if it were slipping at a lower RPM?
Sep 12, 2009 at 1:33 AM
  • 110,248 POSTS
Can you tell aprox where the sound is coming from? Also, a bad differential won't cause the trans to slip or feel like it's slipping.
Sep 16, 2009 at 1:06 AM
MCK57
The sound is coming from the front, but hard to pinpoint exactly where since it only happens when I take it out of park.
Sep 16, 2009 at 11:01 AM
  • 110,248 POSTS
If it only happens when it is out of park, does it do it when you are stopped too?
Sep 16, 2009 at 12:51 PM
