How do I drain some of the transmission fluid if I have too much. The dip stick is reading way too high.
Jun 7, 2010 at 3:59 AM
✓Experienced Mechanic
Check the trans pan. Some actually had a drain plug. If it doesn't, you have two choices. You can get a pump of some sort and place a long hose on it, place it in the dipstick tube and suck some out, or you can loosten the trans pan and allow some to drain slowly from there.
Mar 23, 2021 at 5:19 AM
